speedo cable adapter?
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
was wondering if there was an adapter or something that i can use for my stock speedo cable to get it to work with the autometer mechanical speedo?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: speedo cable adapter?
It's supposed to be compatible. You may need to switch to an auto-meter cable, IdK. But using the A-M speedo with stock speedo gears in a GM trans is no big deal. Call the A-M tech line.
Z28/ZR1
Oct 23, 2015 01:04 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
