need to know if i need this
Old Sep 17, 2010 | 03:52 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
that rubber washer and the carbon brush and spring that are underneath the distributor coil aren't there. Do all distributors need those? or do i need need them? Mine is just a plain stock HEI type.
Old Sep 17, 2010 | 06:29 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: need to know if i need this
Yes, you need them. Otherwise, you won't get your engine started.
Old Sep 17, 2010 | 07:16 PM
0pyders's Avatar
is this the right part? http://www.amazon.com/Warner-C210A-R.../dp/B000BZCOVW (just want to make sure since it's online and i can't find it in regular stores).
Old Sep 17, 2010 | 09:22 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
that will work just fine
Old Sep 17, 2010 | 11:21 PM
0pyders's Avatar
thank you sir.
