Rebuilt 350 shortblock sitting 10 years, still good?
Old Sep 18, 2010 | 09:32 AM
puma1552's Avatar
I bought a professionally rebuilt 350 short block about ten years back, never did finish building it. It's been on an engine stand, oiled fairly regularly and covered with a garbage bag. No visible rust, except a tiny bit on the harmonic balancer that I think should be able to come clean off with a little emory cloth.
Is it still good, or should I assume that it's seized?
Old Sep 18, 2010 | 09:46 AM
InjectorsPlus's Avatar
Former Sponsor
Re: Rebuilt 350 shortblock sitting 10 years, still good?
Sounds like it would be fine.....no rust? Not in the bores? that's what is important.
Old Sep 18, 2010 | 10:08 AM
puma1552's Avatar
correct, just the light bit on the balancer.
Old Sep 19, 2010 | 07:40 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Turn the crank, watch for ring marks in the bores. If none, then it should be fine to build.
Because the assembly lube is so old, you'll definitely need to run an oil pump primer mounted in a drill, before starting it. Turn the crank, slowly, 2 full turns, while a helper runs the drill. You'll need to do an oil and filter change after the first 15 minutes.
hectre13
Dec 11, 2023 08:14 AM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
