zz4 able to use mechanical roller?
Old Sep 20, 2010 | 10:50 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
Is there any issues using a mechanical roller cam / lifters in a ZZ4 crate motor? As far as I know the ZZ4 is the newer 1 piece rear main seal block. I know that Chevy converted from flat tappet hydraulic cams to hydraulic rollers in 87 and know that there is a "conversion" that has to be done to go from a flat tappet to the roller style. Would there be any issues going from the hydraulic roller that is in the zz4 to a mechanical roller? I cant imagine there would be but figured i'd ask. Thanks
Old Sep 21, 2010 | 06:00 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: zz4 able to use mechanical roller?
All the suppliers of solid roller lifters offer a tall style for the later blocks. For daily street use, I would spend a bit more and run COMP's EndureX version.
Pay attention to the advertised lift versus what your heads are machined for.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
dimented24x7
Sep 6, 2015 03:51 PM
