TPI pinhole in fuel line near fuel filter... Help!
Old Sep 21, 2010 | 02:57 PM
68Strat's Avatar
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
I went under my car today, to replace what I believe is a plugged up fuel filter. The lines were incredibly rusty on one side (with newer line on the other via compression fitting) I put light pressure to see if I could break the line loose a bit on the rusted side (after unplugging the fuel pump fuse and starting the car to kill some pressure) but before I hardly got an pressure at all on the line it sprung a small leak spraying the fuel like an injector out under my car... I got the heck out from under there as fast as I could, praying that the spray would not ignite on my warm mid pipe. I am wondering how long it will keep spraying with some pressure left in the line, and if I should get under there and try and break it free more (I am afraid of making a spark!)
And finally how I should proceed.... Cut the rusted line somewhere and use a compression fitting going to the old line up a bit?
Old Sep 21, 2010 | 05:14 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: TPI pinhole in fuel line near fuel filter... Help!
Maybe try the parts store to see if you can get a complete replacement line?
Old Sep 21, 2010 | 05:21 PM
68Strat's Avatar
Engine: 360
Yeah i think I will replace the line, but its rusted to some brake lines that need some replacement so I'll have to make a day of it. To get the car running I am going to use a 2" section of rubber hose to patch the over that area once I cut it out.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
