flames and fuel spitting from my 1406
Old Oct 7, 2010 | 12:28 PM
juneyer90's Avatar
Car: '85 Camaro z28... '90 300zxTT Z32
Engine: soon to be 350(carb)... VG30DETT
like it says I got flames and fuel spitting from my 1406 on a 305
things I've done recently:
1. put fluid in my steering pump
2. changed my ignition wires for brand new ones
3. adjust idle
it was starting when I first put the wires in and now it won't start it's spitting out fuel from the carb and flames occasionaly
please help!!
I have a 1405 carb lying around should I just replace the 1406? or is it the wires? they're brand new. I just printed out the firing order so I'm going to check that also. many things It could be but it was fine a few days ago?
need help-!
Old Oct 7, 2010 | 12:38 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: flames and fuel spitting from my 1406
sounds like a firing order issue...
Old Oct 7, 2010 | 09:41 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
You got your plug wires mixed up.
Old Oct 7, 2010 | 11:09 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
Firing order issue. It is wired up wrong, classic case of "cross wired"!
Old Oct 8, 2010 | 01:46 AM
327sleeper88's Avatar
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
i would also check initial timing, if the timing is retarded too much, fire happens.
Old Oct 8, 2010 | 10:28 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Don't blame the carb, it is 95% likely firing order. It's pretty easy to get the wires one post off on the distributor.
One other thing (and I only mention this because it happened to me) is it could be poor quality fuel... but then you would have noticed a decrease in performance over a couple days to the point where it wouldn't start.
theshackle
Sep 17, 2020 08:26 AM
Golfvette
Aug 24, 2015 06:35 PM
86IROC112
Aug 17, 2015 02:00 PM
matthew911
Aug 12, 2015 09:38 AM
