Just bought my 3rd gen.... afew questions
Old Oct 10, 2010 | 10:29 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
I just bought my 1991 camaro rs it had a 350 with a mild cam swapped into it and a 400 trans i think. I paid $2100 for it. I have a few questions. first of all some of the ignition wires got burnt on the headers so thats getting fixed first. but also the tach is waaaaaaaaay off lol. I read the thread on how to fix it but I have no clue in electrical so my question there is if I buy a redlight tach and install it will it work? also when I shift into 3rd it grinds in is this normal? And then just one more, the idle is too high im thinking this is because of the cam. After I sit for 20 seconds or so idle drops to what sounds like normal. (5,000rpm on the tach lol) So I was wondering if I should just leave it or adjust it. Thanks so much for the help in advance and sorry for the noob questions.
Old Oct 10, 2010 | 11:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
TH400? As in, automatic? Can't say I've ever heard an automatic grind into gear, but that doesn't mean it can't happen.
Does this car have a carburetor now?
Old Oct 11, 2010 | 01:14 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
Re: Just bought my 3rd gen.... afew questions
Well he said it was a 400 trans but it is a 5 speed. He aslo said it was tbi but i havent checked....
Old Oct 11, 2010 | 03:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sounds like you need to figure out exactly what you have. I don't think any 5speed was ever referred to as a '400'. You have a standard 5sp tranny that was probably stock in the car.
Check the engine to see what it is - on the driver side, behind the head, on the top of the block, there will be casting numbers - they are almost impossible to see - try a small mirror and a small flashlight - let us know what you find, because EVERYONE says the car has a 350 when most time it's a 305. the 305 will have "5.0" in that location.
TBI looks like a carb, but when you take the air cleaner off, you'll see 2 injectors inside the unit.
69 Six Pack
Oct 5, 2015 07:51 PM
86IROC112
Sep 7, 2015 01:37 PM
redmaroz
Aug 16, 2015 11:40 PM
johanlindgren
Aug 16, 2015 12:16 AM
reiderz iroc
Aug 13, 2015 04:57 PM
