1982 Firebird 4cyl Fuel Injection Bad idle?
Old Oct 12, 2010 | 08:21 PM
olefirebird's Avatar
Car: 1982 Pontiac Firebird
Engine: 4 cyl
I just bouth this car for 500 bucks. Finally registered it and I am going to start driving to work in this car (30 MPG!) but it seems to idle rough and wants to die sometimes when I change gears or even turn on lights.
I am wanting to know what all should I do to repair this engine and other typical things I should do to just help the overall performance of the car.
I am planning on:
Replacing Spark Plugs
Replacing Wires
Replacing Distributer cap and rotar clip
Cleaning throttle body
New air filter
Oil change (dunno when last one was done)
What else should I do that isn't to expensive but may help the response and power of the engine and create a smoother running car? Thanks!
Old Oct 13, 2010 | 07:31 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: 1982 Firebird 4cyl Fuel Injection Bad idle?
Change/check all the vacuum lines. If they are original, they are sure to be dryrotted and cracked.
Old Oct 15, 2010 | 10:47 AM
Engine: 4 cyl
Thanks for the tip, when you replace vacuum lines do you just go and buy like a certain amount of feet and then start cutting and replacing that way?
Old May 19, 2011 | 10:19 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
how is the idle ?
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
zeitghaist
Aug 18, 2015 07:33 AM
86Base
Aug 13, 2015 05:06 PM
