bad problem
Old Oct 20, 2010 | 06:31 PM
VandykeT/A's Avatar
bad problem
We recently rebuilt the 305 in my car. We put a edelbrock intake, shorty headers and xe 268 cam on it. Now it misses like crazy. It runs very rich and when you stomp it it'll bog and occasionally pop back through the carb. We've had two dfferent carbs, 2 distributors, new wires, plugs cap coil, button everything I know to do. It still does the same thing what could be causing this? I did tighten my rocker arms down to tight and ran it for now more than a couple hours just idling and revving up slightly in the yard. The reason I say that is because somebody told me i could have worn the cam out but I can't see it doing it that quickly. And when i changed the oil there weren't any sparkles in it that I could tell.
Old Oct 20, 2010 | 10:50 PM
COTY'S IROC-Z's Avatar
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: bad problem
maybe cam down!
Old Oct 20, 2010 | 10:58 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: bad problem
Think it's time for a 350
Old Oct 20, 2010 | 11:12 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: bad problem
just put it one the bottle 150 shot that will fix it!!!
Old Oct 20, 2010 | 11:13 PM
VandykeT/A's Avatar
Re: bad problem
I would have went 350 but i was afraid my T5 would shoot its wad.
Old Oct 20, 2010 | 11:15 PM
Firebirda7x's Avatar
Car: 1986 Firebird Trans Am
Engine: Chevy 355
Transmission: Built 700R4
Axle/Gears: 9 bolt 2.77
Re: bad problem
You said you tightened the rocker arms down too tight? Are they not opening your intake valves fully?
Old Oct 20, 2010 | 11:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the rockers are too tight, you'll either not close the valves, or you'll bind up something.
You can easily flatten a cam lobe, or bend a pushrod, or break a valve spring, or punch a hole in a rocker arm, or burn valves/seats - in minutes.
86IROC112
Apr 9, 2016 10:20 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
Bryan F
Aug 18, 2015 02:28 PM
