I NEED HELP!!
Old Oct 31, 2010 | 07:17 PM
andresalvarado's Avatar
Car: 1990 Camaro IROC-Z
Engine: 5.7L TPI
Transmission: Automatic 700R
I NEED HELP!!
I got a problem with my 1990 IROC, it has a 5.7L TPI, it starts and drives but it won't accelerate, it goes up to about 2000 rpm and starts backfiring and shakes a lot, any ideas what it might be?
Old Oct 31, 2010 | 07:46 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: I NEED HELP!!
Any codes? Could be a clogged cat. Is that dual or single cat?
Old Nov 2, 2010 | 03:39 PM
Engine: 5.7L TPI
Re: I NEED HELP!!
Well the truth is that I just got my camaro and don't know too much about it, I would say it's a single cat, it has dual tips coming out to the back but they come out of one single muffler.
Old Nov 4, 2010 | 03:42 PM
BrownBullet83Z's Avatar
Car: '83 Camaro Z28
Engine: "Just a little something"
Axle/Gears: 3:73
Re: I NEED HELP!!
A cat definitily sounds like the culprit but dont forget about the basics. Fuel and ignition. Make sure you have good plugs, wires, cap, rotor etc. Make sure you have correct fuel pressure and volume. Could be misfiring. A quick was to check for bad cat is to remove the 02 sensor. If it gets ANY better, suspect cat. Also make sure you dont have any vacuum leaks or bad MAF (if it has one).
