help before i set it on fire!!!!
Old Nov 4, 2010 | 11:34 AM
infared337's Avatar
89 TA. 305 TPI..car is running sluggish at idle and in drive like its sputtering..took it to a mechanic he tested voltage to the injectors and everything is checking out fine on the passenger side but not drivers side. he stated that when he puts a jumper on the battery from another vehical everything works fine....replaced starter, alternator,battery all cables,cap& rotors, plugs, fuel filter, plug wires..still same problem. please any help would be appreciated
Old Nov 4, 2010 | 11:45 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: help before i set it on fire!!!!
First stop buying parts that have nothing to do with the issue. If the mechanic is correct that one bank of injectors is not being fired correctly then that's where to start. Maybe get a noid light and work back from the injectors checking wires etc. And/or work forward from the fuse. Either the injectors are not be triggered correctly by the ecu or they don't have enough voltage to operate properly. Have you checked the restiance across the injectors?
Old Nov 5, 2010 | 09:58 AM
southbay08's Avatar
resistance on the injectors should be between 12-16 ohm. Also, keep in mind that if they do ohm out ok, that does not mean that there is not a potential problem with them.
Old Nov 5, 2010 | 11:25 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
In rereading your post I see the mechanic said when he jumped from an another (additional?) battery everything worked fine. This suggests the injectors etc. may be ok and the issue is with wiring somewhere. If there is a corroded connection or partially broken wire the extra power from the additional battery may be just enough to overcome the poor connection. Check/clean connections and gently move/bend wires to see if a anything changes. Also, just unplugging and reconnecting things can clean a connection enough to make it work.
LittleFranks
Sep 17, 2015 12:22 PM
TheExaminer
Aug 26, 2015 04:59 PM
86IROC112
Aug 21, 2015 07:20 PM
TheExaminer
Aug 19, 2015 10:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
