90 camaro carb swap
Old Nov 7, 2010 | 02:16 PM
Dakota_Don's Avatar
90 camaro carb swap
Hello, if i swap to a carb on a 90 cam, will I need to do anything for the transmission, its a 700r4..
Will it shift to 4th? LU?
what about the TV cable? is there a bracket for the carb?
Don
Old Nov 7, 2010 | 03:37 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: 90 camaro carb swap
Yes, you will need to get the correct brackets for the tv cable, cruise, etc. I know Holley has these brackets if you are swapping to a Holley, but Edelbrock and Demon should also if you are swapping to those. without the brackets to mount the cables in the correct location, your tranny will not make it long.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
