radiator fluid
Old Nov 8, 2010 | 01:49 PM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
radiator fluid
hey guys, my rads got really dirty fluid im guessing from the car sitting, and im thinking this is causing an overheating problem.. is this true? the car heats up really fast in idle.. anything i can do about this? thanks guys!
Old Nov 8, 2010 | 02:23 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
Re: radiator fluid
The fluid might not be circulating and if it stays dirty too long it can take out your water pump.
Old Nov 8, 2010 | 02:50 PM
Rob00158's Avatar
Re: radiator fluid
What's you're temp gauge saying?
More likely to be water pump or thermostat not functioning correctly.
You may as well pull the bottom hose off the rad, drain the old coolant and flush the rad and block through with a hose pipe. While you've got it drained down you could pull the thermostat, drop it in a mug of boiling water and see if it opens.
Old Nov 8, 2010 | 02:53 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: radiator fluid
For troubleshooting issues, I agree to check the thermostat to see if it is opening properly. No more than what they cost - go back with a new one regardless of what you find.
Old Nov 8, 2010 | 04:15 PM
BrandonSB's Avatar
Engine: 30Slow
Re: radiator fluid
thanks for your input guys!
sheachopper
Jul 31, 2019 11:27 AM
mfp189
Sep 27, 2015 09:25 AM
