fuel pump
Old Nov 11, 2010 | 02:55 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
fuel pump
i needed a new fuel pump because my housing cracked on the one that was on my car, so my friend gave me one off a 307. now the 307s pump fits into the location and is exactly the same except for on thing. my cars fuel pump has two male ends and one female, and the 307s has one male and one female end. now i looked it up and it said that one of the male ends on my car was for emissions which i dont have anymore. what it didnt specify is which one it was. so if anyone can tell me whcih hose i can remove completely to put on the other fuel pump it would be greatly appreciated.
Old Nov 12, 2010 | 06:36 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: fuel pump
The third one is a return line. It has nothing to do with emissions. It has to do with what the pump's internal pressure regulator does with the excess gas. Whether it sends it back to the tank (keeps gas flowing and I hear helps prevent vapor lock) or just keeps it in the pump.
If you want to use that pump, connect the threaded female to your carb line, and the other connection to the thicker of the two lines coming up the frame. Cap off the smaller one.
Old Nov 12, 2010 | 07:28 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: fuel pump
so what exactly is the other line that i can block off for?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
