SUGGESTIONS PLEASE!!!
Old Nov 11, 2010 | 11:59 PM
lonewolf1605's Avatar
I have a 1992 rs with a 305 tbi. When the car is cold it is doing something I cannot find the solution to. When i start the car it runs perfectly for 5 to 8 minutes if it is parked or if i am driving. The tach then starts to bounce erratically and the car refuses to idle. The car also has no power and feels like it is missing throughout the rpm range. If i have to stop at a light the vehicle will die. It does this for 3 to 5 minutes and then corrects itself. It has only thrown a cel twice and it was code 42. I have replaced the coolant temp sensor, distributor, module, cap, rotor, coil, wires, plugs, and the thermostat. I have checked the wire from the distributor to the ecm and the connection is good. If the car has been ran and is warm it will not do this and once it has corrected itself it does not do this again until it has cooled down. Any suggestions would be greatly appreciated.
Old Nov 12, 2010 | 12:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: SUGGESTIONS PLEASE!!!
You've replaced the entire distributor? Checked all the grounds at the engine and ECM?
Old Nov 12, 2010 | 12:33 AM
I have replaced the entire distributor, have checked all wiring and grounds.I bought the car about a month ago and i have yet to find a reason it is doing this every morning. I feel the problem is too consistent to be a loose connection, but i have been wrong before so i checked them anyway. no cigar
Old Nov 12, 2010 | 12:38 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check that the PROM is seated correctly with clean contacts, and if that doesn't work, try another ECM.
Old Nov 12, 2010 | 12:39 AM
I have resorted to starting the car early enough so it can go through its "cycle". I can then get where i am going without issue.
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
