Idle Randomly Surging at stop lights?(Video Included)
Old Nov 14, 2010 | 02:00 AM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
91 RS Camaro 305 TBI
Recently the car has been acting weird when i get to a stop light.
This happens id say about 50% of the time, sometimes it will happen and sometimes it wont.
Heres the video of the surging, hopefully someone can help me identify what the problem is, the car hasnt died while surging even though it feels like it wants to, even the lights dim a little when it surges.( sorry about the ticking was about to turn at the light)
http://www.youtube.com/watch?v=WCA_Z...layer_embedded
Im positive this isn't a vaccum leak, i suspect its the timing? Or does timing not cause this?
I had my timing recently set at a shop, first i had set my timing to 0 and the car ran horrible even though that was the stock spec, so the shop set the timing to a custom setting which im not exactly sure what it was.
Whats the best setting for the timing on a 305 TBI?
I also suspect maybe the EGR? could it be that its bad and can it cause this?
Any info appreciated
Old Nov 14, 2010 | 05:43 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Idle Randomly Surging at stop lights?(Video Included)
Positive? Tell us why.
Your missing the point on this one.
If zero is stock and there are no extensive mods then it should run like a bat out of hell. Make it run like stock then mod the timing if it needs it.
You need to know what the timing was set to, ask, then check it yourself.
EGR wouldn't cause a surge, most likely to cause a stall, by my experience.
Lastly, the ECM thinks the initial timing is zero, and as long as it doesn't knock it's happy, but due diligence would be to verify timing marks at DTC with a piston stop. If everything is properly aligned then reprogram the chip with the new setting.
Well that's what I would do.
Old Nov 14, 2010 | 01:12 PM
Car: 1986 Iroc-Z
Engine: 355
Well im positive because every problem that i had with this car in the past i always associated it with a leak.. To the point where i checked every possible hose, replaced about 5 cracked hoses etc. If there is one left il be surprised but i guess another check wont hurt.
I don't have any extensive mods only mod i have performance wise is a homemade cold air intake through the high beams. I guess ill head over to the shop today and see if i can get it re adjusted to 0
Old Nov 14, 2010 | 04:45 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Did you check the IAC, it may need to be cleaned or even replaced.
Old Nov 14, 2010 | 05:23 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I had a problem similar to this. I replaced the throttle positioning sensor, and it went away. Mine acted up sometimes when I had the high idle and I moved the shift, it would surge even more (700r4).
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Omega
Aug 10, 2015 12:46 PM
