head/intake vacuum
Old Nov 25, 2010 | 11:02 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
head/intake vacuum
Think I have an intake leak between my intake and heads on a new motor. The heads were milled .005 but the intake is a stock Edelbrock hi-flo TPI base. Being the heads were milled does the intake also have to be milled to seat correctly? Thanks
Old Nov 25, 2010 | 12:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: head/intake vacuum
At only .005" I wouldn't think it would make it necessary to mill the intake manifold to match. What gives the impression you have a vacuum leak at the manifold?
Old Nov 25, 2010 | 07:12 PM
Car: 89 Formula 350
running lean at idle and when i spray starter fluid between the head and intake it runs richer
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
