Blown Intake Seal
Old Nov 29, 2010 | 03:50 PM
krazefbird's Avatar
Car: 84 Firebird
Engine: currently 1968 307
Axle/Gears: 3.23 lim slip
Blown Intake Seal
Just want to hear some ideas on why my intake seal might be blowing so much. I have a '68 307 engine with an edlebrock performer intake and 600 cfm carb. This was a throw together motor so not sure on all the little details. I have had the intake for maybe 8 years or so? Started on the stock 305, then went to a 350, and now to the 307. The engine was running pretty crappy a couple months back so I tore it apart a little bit and addressed a few issues. One of them being a blown intake seal front and rear. Got it back together and it was running like a champ. Now it is running crappy again and I can see the rubber seal coming out from between the RTV so same thing again. But why? Too much pressure in the intake? Should I have not put the rubber seals in? I've heard guys just leave those out and use RTV but if I do that then how well will the RTV hold? Would adding a breather on the valve covers help alliviate the problem? Let me know what you think, I really hate having to pull the intake off all the time. Thanks
Old Nov 30, 2010 | 12:46 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Blown Intake Seal
You should have a PCV system, or at least a breather to allow the blowby to escape the crankcase. Not having a PCV system will cause sludging.
The rubber china wall seals do come out from time to time. I used them in the past, and sometimes they work, sometimes they dont. If you dont have a breather, then they will blow out in short order. As for sealing, RTV is teh best method. Make sure its good RTV and not the cheap colored silicone crap.
Old Nov 30, 2010 | 05:01 PM
krazefbird's Avatar
Car: 84 Firebird
Yeah I have a PCV on the one valve cover that goes back up to the carb. The other valve cover has a breather on it but it is only looks(I found this out when I tore the top end apart last time) Just need to get a different rubber grommet so it will be functional. Oh, my cam is a comp cam with .470/.470 lift, would that make a difference with the intake pressure? When I put the Intake on last time I used permatex high temp RTV, the red stuff. It had always worked good for me before but now.....yeah. Do I need to get a different RTV? What kind would you reccommend? Thanks for the help.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
