how to test a fuel pump?
Old Dec 8, 2010 | 03:43 PM
carcrazy1's Avatar
Does anyone know how to test a fuel pump and drain the fuel tank with out pulling it? Ide like to get all the gas out cuz its been sitting a while and want fresh gas with my new fuel injectors also want to make sure my pump is working right.
Old Dec 8, 2010 | 04:26 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: how to test a fuel pump?
I have no idea how to tell if the pump is working right cause if it works it's good enough for me. The only way I can think of draining the tank without taking it out is going to take a while; the feed line off the pump gets run to a bucket and you crank and crank and crank or cut a hole in the floor where the pump is, take the pump out and siphon it all out.
Old Dec 8, 2010 | 04:56 PM
AmorgetRS's Avatar
Buy a siphon for like 5.99 at the local parts store and stick it down the fill tube. No need to hack your car up just to drain the fuel.
As far as testing, get a fuel pressure gauge, hook it to the rail, turn key and check the fuel pressure. That is about as good as a sign as anything.
Old Dec 8, 2010 | 06:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by carcrazy1
Does anyone know how to test a fuel pump and drain the fuel tank with out pulling it?.
12V to terminal G on the ALDL connector under dash will make the pump run full time ( assuming your fuel pump relay is good )
Old Dec 8, 2010 | 07:27 PM
carcrazy1's Avatar
Cool thank you very much!!! Do u know what one is terminal G? Maybe a pic if possible?
Old Dec 8, 2010 | 07:53 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
http://autorepair.about.com/library/images/bl428lib.htm
Old Dec 8, 2010 | 08:07 PM
carcrazy1's Avatar
Awesome! Thank you guys soo much you have been extremely helpful! And by the way I'm new on the site and new to owning a camaro. Nice to meet you all!!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
