q-jet to holley hooking it up?
Old Dec 8, 2010 | 07:05 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I was trying to hook up a used hollet 600cfm that I got but the linkages to hook up the throttle and transmission cable are different. Am i supposed to used the ones on my q-jet. On THE Holley itself there is a long metal bar where the cable is supposed to be attached?
Old Dec 8, 2010 | 07:24 PM
MikeSammy's Avatar
Re: q-jet to holley hooking it up?
also, I lost the clip that holds the throttle cable onto the linkage arm, where can i get another
Old Dec 9, 2010 | 02:21 PM
MikeSammy's Avatar
bump for any suggestions?
Old Dec 9, 2010 | 03:26 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You'll need the specific adapter for the TV cable for the Holley carb. Hope you also swapped out the dist for a mech/vac one now that the computer is no longer controlling it?
Old Dec 9, 2010 | 03:44 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
I suggest showing us a picture of what you have. I dont know what you mean by long metal bar.
Do you have an appropriate bracket that holds the cables in place? http://www.summitracing.com/parts/HL...n/?prefilter=0 The one from the quadrajet doesnt hold them the proper distances from the carb.
Do you have the (overpriced I think) tv geometry bracket http://www.summitracing.com/parts/HLY-20-121/ naf mentioned so you dont ruin your transmission?
I know I've seen the clips at either the car parts stores or in the drawers at lowes.
Old Dec 9, 2010 | 06:42 PM
MikeSammy's Avatar
The came with a distributor with vac can but I bought a newer 65k volt one that im putting in. Also the metal bar has a threaded end which threads into the braket and then was attached to a cable in the firewall.
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Royal_Z
Sep 30, 2015 08:45 PM
Gordonr1973
Sep 29, 2015 11:59 AM
dusterbd
Sep 29, 2015 08:40 AM
