Cylinder head bolt question
Old Dec 9, 2010 | 12:54 PM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
In the process of changing a head gasket and when I removed the bolts they looked to be only two sizes. In the pack of new ones I bought there are 7long ones, 8 short ones and 2 that are not as long as the long ones. Where do the two go??
Old Dec 9, 2010 | 01:11 PM
joeld's Avatar
Car: 1986 Firebird, 1989 Vette, 1995 GP
Re: Cylinder head bolt question
The two "middle" lengths go at the far end under the valve cover. They go right next to the oil drain back holes in the ends of the head.
Joel
Old Dec 9, 2010 | 01:14 PM
megtom2's Avatar
Engine: 350 tpi
Transmission: 700
Thank you. I figured they went at each end but would rather ask first before I started torquing them down.
Old Dec 10, 2010 | 03:40 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Yeah thats pretty confusing the first couple times. My dad built so many small blocks he had 3 5 gallon buckets full of the different length bolts. That was the first thing I learned about working on cars...... sorting those bolts.
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
