VATS...Need some help
Old Dec 12, 2010 | 02:32 PM
Messejichael's Avatar
Car: 1991 L98 z28 camaro
Engine: 5.7 TPI 350 (GM stock replacement)
Axle/Gears: 3:73
My key is stuck in the cylinder in the on position( won't return to off ) so i was having to turn my car off by unplugging the Dist wire and unplugging the battery...that was working for a while and then all the sudden it wont start at all when i turn the key....Did the VATS engage and lock me out? I have no clue as to how i can solve my problem or where to even start...i have power to all my accessories but doesnt sound like the fuel pump is even turning on when i plug the battery back in like it used to when i was unplugging it and plugging it back in....any suggestions on this? or am i just doomed to having a dead car? cuz if i am i have the biggest radio on the planet...and that doesn't get me to where i need to go...LOL
Old Dec 12, 2010 | 04:02 PM
Axle/Gears: 3:73
Re: VATS...Need some help
exnay on the fuel pump engaging, i hear it now when i plug the battery in, and also hear the injectors squirting fuel...so now what? Bad starter? starter relay? the starter was clicking a few times before i could get it to turn over when it would bump the starter, but now there is no bump...can i rule out the VATS now?
Old Dec 12, 2010 | 05:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Messejichael
the starter was clicking a few times before ... now there is no bump...can i rule out the VATS now?
Is the battery fully charged?
Have you run a hot wire direct to the stater solenoid terminal to confirm starter actually works?
If starter works properly then could still be faulty VATS or starter enable relay
Old Dec 12, 2010 | 10:12 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
if there is a vats problem the security light will come on. and the starter and fuel injectors are disabled.
Old Dec 12, 2010 | 11:09 PM
Axle/Gears: 3:73
ok so how to i disable the VATs if i find out thats the problem?...the security light is on but the key is stuck in the cylinder and wont return to off...but im pretty sure the security light always came on when i fire the car up then turns off shortly after the car starts up...where is the starter relay?
Old Dec 12, 2010 | 11:23 PM
Stephen's Avatar
Car: 87 GTA
ok so how to i disable the VATs if i find out thats the .....
My 3 most used pics of all time! I think I post these 3 pics every month, yet nobody can ever find them by doing a search. :roflmao:
Old Dec 13, 2010 | 02:04 AM
Axle/Gears: 3:73
hahaha....yeah..i noticed these pics a couple times in other threads...thanks again though
