Can someone please tell me what this is under my hood?
Old Dec 14, 2010 | 12:44 PM
92RSGirl's Avatar
I'm selling my car and the buyer wants to know (and so do I) what this tube/opening is. It's right in the center of the picture. When the car is running this tube is sucking air. Now, the car has had a new air filter put on, not the stock one. We are guessing this connected to the stock filter, but not sure. So, if anyone could tell me what this is and the purpose/function of it and if it is a problem leaving it the way it is it would be greatly appreciated!
Thanks,
92RSGirl
Attached Thumbnails Can someone please tell me what this is under my hood?-unknown-opening-under-hood.jpg
Old Dec 14, 2010 | 12:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can someone please tell me what this is under my hood?
AIR check valve, part of an emissions system that appears to have been removed.
Old Dec 14, 2010 | 12:49 PM
92RSGirl's Avatar
Thanks for the quick reply! Is there any harm in leaving it this way? Does it affect anything?
Old Dec 14, 2010 | 12:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're sure it's sucking air? Does the one on the drivers side do it too?
Old Dec 14, 2010 | 12:57 PM
92RSGirl's Avatar
Yeah, there is suction. I didn't even see another one on the driver's side, hmmmm. I know the previous owner replaced the air compressor system, maybe that has something do with it?
Old Dec 14, 2010 | 02:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's going to let extra air into your exhaust. On the passenger side it's not too much of a problem, but the O2 sensor is on the driver side.
It can be fixed easily enough by taking the injector tubing out and plugging the holes in the manifolds.
Old Dec 14, 2010 | 02:41 PM
92RSGirl's Avatar
Thank you very much!
Old Dec 14, 2010 | 02:45 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
which car are you selling?
Old Dec 14, 2010 | 02:53 PM
92RSGirl's Avatar
Here's the link:
https://www.thirdgen.org/forums/cama...ro-rs-5-a.html
Old Dec 14, 2010 | 03:11 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Looks like that is actually the tube that goes to the catalytic converter. Same purpose. The AIR system would have three, one going to each exhaust manifold and one to the cat. It might can be capped at the end shown with a rubber cap and hose clamp or the pipe nearer the cat can be cut and crimped shut. If the cat has been replaced at some time this line may have already been cut and reconnected to the new cat.
Old Dec 14, 2010 | 03:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I think you're right.
Old Dec 14, 2010 | 03:28 PM
92RSGirl's Avatar
Oh ok. Well the cat was removed on this car so I guess that explains it. Thanks!
Old Dec 14, 2010 | 06:47 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
nice looking car you had
Old Dec 14, 2010 | 06:52 PM
92RSGirl's Avatar
Thank you. Technically I still have it...trying to work out long-distance deal.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
