Heat is not working in my car. How do I fix it???
Old Dec 18, 2010 | 11:58 AM
Z28_1991_Camaro's Avatar
Car: 1991 z28
Engine: 5.7L
I have a 95 Honda Accord that I drive in the winter time and the heat is not working on it.
I felt both hoses from the heater core and they both feel warm. The thermostat appears to be functioning. My coolant level is good and I made sure there was no air in the system.
The air getting blown in the car is warmer than the outside air but I wouldn't say that its warm air...just warmer then outside.
Where should I begin to troubleshoot?
Old Dec 18, 2010 | 10:21 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
Re: Heat is not working in my car. How do I fix it???
thermostat may not be opening all the way
Old Dec 20, 2010 | 01:13 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You've checked all the basics already. I'm not sure how Hondas control the hot/cold door on the HVAC box, but it's either cable, vacuum, or electric motor. Since both heater hoses are hot, that's where I would check. See if the door is jammed or not being actuated properly.
Old Dec 20, 2010 | 02:13 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
If its not a blend door issue theres a possibility that there could be an animals nest in your heater box... Not totally uncommon, I think my roomates Ford Taurus has the same problem. Its warmer than ambient, but not by much. I'd pry open the case gently with a good flashlight and see if there is anything build up in front of the core (sorry, I'm not a big Honda guy).
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
