Valve covers
Old Dec 20, 2010 | 09:39 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Valve covers
I just bought a 350 engine and i hate the black valve covers on there right now. Im making this engine a carb and im using an airgap intake by SBC. My first question is do i need to still use the breather holes? And if not can i get valve covers that have no breather holes on top except for the center bolt holes? the pictures i posted are whats on there now
Old Dec 20, 2010 | 09:42 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Re: Valve covers
Could it be possible using these? They dont have the oil cap on top http://www.midwestmotorsportsinc.com...961&parent=294
The two breather holes on top, do i really need them since im running carb? if not would it be possible to use these types with no holes? http://www.midwestmotorsportsinc.com...001&parent=294
Old Dec 21, 2010 | 10:17 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Valve covers
you will need holes.
one for pvc, other for breather.
Plus without holes where you planning on putting oil in the motor?
Old Dec 21, 2010 | 10:31 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Re: Valve covers
I understand now that i need the holes but instead of having the tubes couldnt i just buy filters and put them in place of where the breather and pcv go?
Old Dec 21, 2010 | 10:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Valve covers
Yes, if you don't mind cleaning up the mess.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
