O2 sensor question...
Old Dec 26, 2010 | 12:06 PM
hassgrant's Avatar
Car: '91 Z28 305 TPI
Transmission: Manual
I have a 91 Z28 305 TPI. I have been fighting an acceleration issue for awhile. First I thought it was the EGR system, but everything checks out fine (although I will throw code occassionally when cruising, but I have a solenoid off of a 91 305 Caprice). I decided to check the O2 sensor and found that I am not getting any reading from the O2 sensor or the O2 sensor connector from the ECM on my voltmeter. I mean, nothing, zilch, zero. I made sure I had a good ground for the voltmeter and made sure the voltmeter was working. The other thing I find weird is that I am not throwing any codes for the O2 sensor. I just replaced the ECM but I did not replace the prom. So is it as simple as a bad O2 sensor, which is only about a month old, or is it my O2 sensor connection? Any help is greatly appreciated. Thank you!
Old Dec 26, 2010 | 12:37 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Re: O2 sensor question...
Usually the output range of an O2 sensor is only .2 to .7 volts. If you try to test resistance with a voltmeter you will probably ruin it. Hard to detect that reading with a low quality testor.
Old Dec 26, 2010 | 12:45 PM
hassgrant's Avatar
If the O2 sensor is ruined, shouldn't it throw code? Just seems weird that if the O2 sensor wasn't giving any reading it should give code. I do know that the car runs great in open loop but has a fall-off in acceleration once it enters closed loop. In open loop, throttle response is great, but there is a weird, hesitation between hard throttle and throttle response in closed loop. It almost as if the car is taking a gulp of air or if the car is slow to respond to the hard throttle. It is a problem I have been chasing for couple of months now. Thought I had it down to wrong EGR Valve, but changed out an no change. Perhaps now it is an O2 sensor issue. These types of problems drive me crazy, LOL!
HoosierinWA
Oct 7, 2015 10:15 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
