Excessive heat - should I be concerned?
Old Dec 29, 2010 | 11:57 AM
joef2002's Avatar
This happened when we had our car in a parade several months ago. Outdoor temp was maybe 60-70 deg F. The parade was extremely long (2+ hours) and the car basically just idled the entire time while inching forward at < 5MPH. Towards the latter half, I could see a light / white smoke coming from the passenger underside (outside the car, not inside). It wasn't very noticeable unless you looked really hard, but it was definitely there. I could also smell the fuel tank purge valve (over the rear wheel) releasing gas every so often.
Given the unusally long idle time we had that day, should something like this be expected? The engine didn't seem to overheat. The car didn't stall. And I have the 3" hooker welded all the way to the tailend (it's a few years old). Nothing was done underneath the car prior to when it happened (no paint, etc.). Any insights guys? Should I be concerned?
Old Dec 29, 2010 | 01:41 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Excessive heat - should I be concerned?
was that the only time you saw smoke?
Old Dec 29, 2010 | 04:37 PM
joef2002's Avatar
The car is not a regular driver, but the times I do drive it I haven't noticed the smoke. Then again, I'm usually going must faster than 5 MPH, so maybe it's there and I just don't see it.
Old Dec 29, 2010 | 04:44 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
what did the temp gauge read? as long as that didnt get over 235-240 (electric fan kicks in at 230) youll be fine or if it has a clutch fan same thing
Old Dec 29, 2010 | 05:00 PM
joef2002's Avatar
didn't happen to notice the actual temp, but the reading seemed normal (needle wasn't outside it's normal range). The fan is always on from the moment I start the car (I know...that's not how it should be, it's just an issue from a PO that i have yet to figure out.)
Old Dec 29, 2010 | 05:04 PM
Car: 1990 camaro RS
Engine: 305 TBI
it should be fine then i cant tell you where the smoke was from but if it was from the cooling system venting coolant it wasnt overheating just expanding some, shouldnt have done any damage
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
mfp189
Sep 27, 2015 09:25 AM
