where my fuel go!
Old Dec 30, 2010 | 03:16 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
where my fuel go!
so i park my car for the winter about 2 months ago with little over 1/4 tank and todays i went to go start it and gas was gone. where did it go?
Old Dec 30, 2010 | 04:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: where my fuel go!
That much would not have evaporated, either there's a leak, or it was stolen.
Old Dec 30, 2010 | 06:44 PM
Engine: 355
well the car is under a tarp inside our fance in back yard so couldnt be stolen and i have look it over i dont see and there is no leaks. i have a mechanical fuel pump i ask a friend and he thinks the fuel pump is letting the gas in the oil?
Old Dec 31, 2010 | 09:52 AM
87blackz28's Avatar
same thing happen to me ..i had a full tank of gas and let the car sit for about a month ..i got in the car and noticed more than a half a tank was gone i thought it was just the gauge..*** to find out the fuel pump was bad and it let fuel in my block...i drained the oil and it was black gas...GET A NEW FUEL PUMP
Old Dec 31, 2010 | 12:06 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Bad fuel pump filled my original engine with gas two owners ago. Last owner bought it barely running, went to change the oil and it was full of gas. Then he discovered the rings were wiped out and resold it.
Dont run the engine until you've checked the oil. Should be simple enough. And if you use a clean pan you can save the oil if its not bad and not full of gas.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
