Edelbrock fuel pump question
Old Jan 1, 2011 | 09:55 AM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
I have a edelbrock 1721 and purchased a 1798 adapter plate to much the lines to the bottom of the pump. Edelbrock sent very little info about installing, but my question is do you keep or remove the bottom diaphram as far as I can tell it is removed in the instruction picture. Just making sure before I install it.
Old Jan 1, 2011 | 10:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Edelbrock fuel pump question
I'm not sure if you'd keep it or not. Are you sure that bottom feed lines will fit?
Old Jan 2, 2011 | 06:57 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Yeah I have the fuel hoses hooked up. I cant find a solid answer. But to me it looks like it would block the fuel from coming thru. I will call edelbrock or summit tomorrow.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
