Upgrading Fuel Pump
Old Jan 7, 2011 | 10:20 PM
BrianN1992rs's Avatar
Car: 1992 Camaro RS
Engine: 350 now
Transmission: Stock 4 auto
Upgrading Fuel Pump
Looking to upgrade my fuel pump with 305 to 350 conversion. I heard Walbro was a good brand. Looking at the 190 and 255 sizes. Any advantages with the different sizes? Will I need to upgrade any lines with the added pressure? Thanks for any help!
Old Jan 8, 2011 | 12:02 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Upgrading Fuel Pump
you haven't specified much info, like mods, fuel system type, etc...
Old Jan 8, 2011 | 06:50 AM
89Formula50's Avatar
Car: 89 Firebird Formula
^^^^ Agree. We would need to know a little more about the motor to be able to help you out. But on a guess. I would use the tpi pump. I heard good things about it. Plus you wouldn't have to upgrade anything just make sure you swap injectors if your running the tbi.
Old Jan 8, 2011 | 10:42 AM
Car: 1992 Camaro RS
Engine: 350 now
Here's a little more info: stock fuel pump in camaro right now. I'm swapping out the 305 tbi for a 350 tbi using the same throttle body and upgrading the injectors from 40 lb/hr (i think that is close to stock) up to 55 or 65, whatever I can find. Some posts I've read say to upgrade the pump on this switch. Will the fuel regulator be able to handle the extra load? Hopefully this is enough. Yes, I will also be getting a chip and ESC Module for the swap.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
gta90
Sep 15, 2015 04:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
