specs
Old Jan 18, 2011 | 05:51 PM
wformula91's Avatar
Car: 91 Firebird Formula/92 Firebird
Engine: 5.0/3.1
Axle/Gears: Factory
specs
if anyone could send me a list of full specs for a 91 firebird formula, factory, engine, tranny, gears, compression, etc. that would be awesome, thanks.
Old Jan 18, 2011 | 06:04 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: specs
https://www.thirdgen.org/1991-pontiac-firebird
this site has tons of info on it...do a quick search, youll find all you need
Old Jan 18, 2011 | 10:00 PM
wformula91's Avatar
Engine: 5.0/3.1
Axle/Gears: Factory
Re: specs
haha ive seen that, but im retarded, so i was more looking for like, what transmission do i have, its an automatic five speed, like is it a th400? or what? and what motor do i have if it is a 305 tbi, L98? sorry and thanks
Old Jan 19, 2011 | 11:57 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: specs
If the tranny is an automatic, then it's a 700R4.
The 8th digit of the VIN number will tell you what it was made with:
T = 3.1 litre V6 Multi Port Injection
8 = 5.7 litre V8 (350) Tuned Port Injection (TPI) L98
E = 5.0 litre V8 (305) Throttle Body Injection (TBI) L03
F = 5.0 litre V8 (305) Tuned Port Injection (TPI) LB9
Engine specs (hp/torque) can be seen at this Wiki: http://en.wikipedia.org/wiki/Chevrol...l-block_engine
Rear gears - more than likely if it's a TBI then it will have 2.73 peg leg (not positraction). I don't think TBI cars with auto's ever had anything else. Some TPI cars had 3.23 or 3.73 rear gears and positraction. A few had 2.73 positraction. Unless you know for sure that the car has never had a rear swap or gear swap, the only real way to know what's inside the diff is to open it up and look.
Your RPO codes will tell you alot of info as well - we have an RPO decoder here: https://www.thirdgen.org/rpodecoder
This is of course all assuming that the car is all still factory and no previous owner has changed anything out.
Off the main page of TGO, there are Technical Specs, Technical Articles, and Third Gen Tech FAQ (links on the left hand side) - some great reading there! And the function here works great!
Old Jan 19, 2011 | 07:03 PM
wformula91's Avatar
Engine: 5.0/3.1
Axle/Gears: Factory
Re: specs
thanks. all of this will help me a lot. i still have a lot to learn haha
Old Jan 19, 2011 | 08:02 PM
Car: 1992 RS
Engine: Carbed 350
Re: specs
You've come to the right place to learn - if it's 3rd gen F-body related, it's in here!
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
