Question:::
Old Jan 23, 2011 | 12:03 PM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
Question:::
I'm not sure if this is the right spot for this question, i have an 84 trans am and it gets very hot inside, especially the centre console. Just wondering if anyone else has this problem either. My old 86 firebird was the same way. Thanks for any responces.
Old Jan 23, 2011 | 12:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Question:::
It's normal, the console is right over a hot transmission and right next to a hot catalytic converter.
Old Jan 23, 2011 | 12:21 PM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
Re: Question:::
Yeah that makes scense but i didn't know if it was normal to be really hot
Old Jan 23, 2011 | 12:25 PM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
Re: Question:::
Is there something i can buy to stop some of the heat getting through, i'm changing the interior soon so it dosen't matter if its something to go under the carpet or anything.....
Old Jan 23, 2011 | 12:45 PM
GeneL's Avatar
Car: 1983 Camaro Sport Coupe, T-Top
Engine: LG4 5-Liter V8, 305cid
Transmission: NWC-T5 Manual 5-speed
Axle/Gears: GU5 Axle Ratio 3.23 Rear
Re: Question:::
I had that same problem when I purchased my '83 Camaro new back in, well....'83.
I have a 5-speed manual and after taking delivery I became aware that the shift area and console were noticeably much hotter than what would be considered "normal". Although at first I was told by the dealer it was normal, I persisted and finally they found some kind of a "heat protection plate", or whatever the nomenclature is, was missing under the console. After the plate was installed (under warranty of course), the heating problem went away.
Gene
Old Jan 23, 2011 | 06:33 PM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
Re: Question:::
That's good info, thank you for letting me know that!
