What pipes run from the oil filter housing?
Old Jan 27, 2011 | 05:19 PM
lonesomeloser's Avatar
Car: 1983 Z28
I am stripping my 89 block down and there are 2 metal pipes that run from the oil filter housing around the front of the engine to the pass side. I notice my 85 doesn't have these.
Old Jan 27, 2011 | 05:21 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: What pipes run from the oil filter housing?
Those flow coolant from the radiator; factory GM oil cooler setup.
Twin_Turbo's Avatar
that's the KC4 engine oil cooler, the lines are coolant lines. They hook up to a set of hardlines mounted on the block using oil pan bolts and on the other side a fuel pump cover bolt
Old Jan 27, 2011 | 05:35 PM
Car: 1983 Z28
Thanks for the fast replies. Anyone have a diagram of the full circuit? Guess it's one more thing to add to my list.
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
