Need again ASAP
Old Feb 5, 2011 | 08:24 PM
CamaroSpeed's Avatar
Car: 1987 IROC
Engine: 305 Tpi
Transmission: 700r4 With B&M Rebuild Kit & 2800 S
Need again ASAP
Ok guys. I replaced the FPR and the fuel pump. I have checked the fuel filter. The car still will not start. I took out the spark plugs and the motor was flooded. Cranked it over to pump out gas in the cylinders. I put a used set of plugs in and tried to start it and would not start. I then pulled the plugs out and the plugs were full of gas. The motor is getting way to much fuel. Any ideas?
Old Feb 5, 2011 | 09:41 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Need again ASAP
Adjustable FPR??
I don't know how much TPI needs // uses, sounds like too much pressure, OR injectors malfunction. Return line blocked?
Just some ideas.
Old Feb 5, 2011 | 09:44 PM
Car: 1987 IROC
Engine: 305 Tpi
Re: Need again ASAP
Yes adjustable FPR. Fuel injectors are 1-2 years old. I do not know which one is the return line.
Old Feb 5, 2011 | 10:01 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Need again ASAP
Is it firing?
Old Feb 5, 2011 | 10:04 PM
Car: 1987 IROC
Engine: 305 Tpi
Re: Need again ASAP
If you mean it has spark at the plugs and coil, then yes.
Old Feb 6, 2011 | 02:34 PM
Engine: 355
Re: Need again ASAP
Why did you replace the FPR and the fuel pump?
Old Feb 6, 2011 | 02:57 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Need again ASAP
Once the plugs are wet fuel fouled they will not fire unless you cook the fuel out of the tips with a propane torch, - that or install new plugs.
You can initiate "clear-flood mode" in a TPI car by pressing the gas pedal to 3/4 before turning your key forward to start the car.
Besides having too high a fuel pressure at the rails, a very cold reading at the engine coolant temperature sensor will cause excess fuel to be injected in during cranking.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
