Need More Help ASAP
Old Feb 6, 2011 | 11:54 AM
CamaroSpeed's Avatar
Car: 1987 IROC
Engine: 305 Tpi
Transmission: 700r4 With B&M Rebuild Kit & 2800 S
Need More Help ASAP
ok replaced fuel pump and pfr still wont start motor is flooded pull plugs turned over motor to get fuel out put used set of plugs still no start if i unplug the injectors it fires off but wont run plug them back in and nothing happens unplug again and fires off going to replace the temp coolant senor and O2 sensor next what do i need to look for or do HELP
Old Feb 6, 2011 | 02:00 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Need More Help ASAP
Sounds like a leaky injector or O-ring. Have you checked the fuel pressure? I think a 305 tpi should be 39lb's on the rail for 19lb injectors. Also you can ohm out the injectors to find a bad one.
Old Feb 6, 2011 | 03:08 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Your O2 sensor is not used at all during cranking/starting, so that cannot be the problem.
The coolant temp sensor is definitely used for cranking. You can easily test it with an ALDL scanner or manually with a DVOM.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
