Motor Vibration
Old Feb 9, 2011 | 10:58 AM
sylentnite's Avatar
Car: 1989 Trans AM
Engine: 383
Motor Vibration
Had my motor(L98) rebuilt last year and had it upgraded to a 383. I noticed that I get a lil more vibration since the rebuild mainly around 1800-2000 rpm range at a stand still. My question is if the motor is out of balance would it vibrate at any rpm range, or would it just depend?
Old Feb 9, 2011 | 02:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Motor Vibration
I don't have a good answer for you, sorry. But I'm local to you - sent you a PM.
Old Feb 10, 2011 | 10:47 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Motor Vibration
No they either vibrate at low rpm like yours or if real bad they shake all the time. You said you have a 383 is it externally balanced or internally? You may have an externally balanced crank with stock internally balanced flywheel or balancer.
Old Feb 11, 2011 | 08:11 AM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: Motor Vibration
I had the wrong harmonic balancer on an old camaro I had and it would vibrate in the high rpm's but not in the low. The higher the rpms the worse it would vibrate. I got the right HB and the vibs went away.
hydrolic144
Sep 8, 2015 06:55 PM
Americanmouse
Sep 7, 2015 12:10 PM
greenyone
Aug 29, 2015 11:08 AM
db057
Aug 22, 2015 08:17 PM
spaigo
Aug 21, 2015 07:46 PM
