lt1 fuel pump switch?
Old Feb 11, 2011 | 12:20 PM
Dr. Phil's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
I have a 97 camaro ss with a lt1 that has a hard start issue when cold, i found that the fuel pressure isnt holding after the initial prime. Ive been told that there is a check ball in the fuel pump that holds pressure at the fuel rails. So everything is peachy after the car starts running, but because the pressure bleeds back to the tank so fast, it makes the car just hard to start. The logical thing would be to pull the tank and install another $200 fuel pump, but i had an idea.
If I install a switch to keep the pump on so that the pressure at the fuel rails will stay high enough the start the engine, will there be any ill effects? I had a similiar setup with my trans am, i had a carbed 383, but had an efi pump so I had to use a switch and 2 regulators to drop the pressure enough. Like i said, the pump works fine, but it just makes the car hard to start, should I install a switch until the pump finally bites the dust?
Old Feb 11, 2011 | 12:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: lt1 fuel pump switch?
I also own a 1997 LT1 - but I'm no expert there. I'd think if the pressure wadropping so quickly between prime and start, that maybe there's an issue with the fuel pressure regulator? But where that is exactly, how to diagnose/repair/replace etc. I have no clue - I've never had to do much to my LT1 (yet).
Probably be better asked on a 4th gen board - some of us have 4th gens and know some about them, but your limiting your responses greatly by asking here.
Good Luck!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
92camaroJoe
Aug 13, 2015 06:07 AM
