fuel pump question
Old Feb 13, 2011 | 01:51 PM
my87_5spgta's Avatar
fuel pump question
Just want to be sure,,if i jumpped the plug coming off the gas tank with 12volts the fuel pump should kick rt on if its working rt?
Old Feb 13, 2011 | 01:55 PM
face215's Avatar
Car: 89' GTA
Engine: L98 with tpi to carb swap
Axle/Gears: stock
Re: fuel pump question
I believe it will, just find the right lead!
Old Feb 13, 2011 | 02:00 PM
There are only 3 so i hit each one and nothing
Old Feb 13, 2011 | 04:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Think about it
One of the 3 wires is a ground wire for the pump and tank gauge and with plug disconnected you have
NO ground
so how is pump supposed to operate ???????
Connect up ground wire on plug to a good ground and try again
Old Feb 13, 2011 | 05:25 PM
Re: fuel pump question..
Lol i did.i used my spare battery and ran two wires from i. I touch each end of the plug.i used a test light for my pos side wire so id know when i would touch the grond lead.i did it everyway possible and not even slight noise click nothing.my test light did light up so i know i had current going to the plug..
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
