Headlight Help??
Old Feb 18, 2011 | 09:00 AM
Andrew1320's Avatar
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
Headlight Help??
Does anyone know how to fix the pop-up headlights on a 1990 Pontiac Firebird. the driver side pops up no problem but the passenger side won't. The motor or vacuum motor runs but the headlight won't come up. Can anyone help??
Old Feb 18, 2011 | 11:15 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Headlight Help??
will help - there's at least a post a week about these.
Old Feb 18, 2011 | 11:25 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
uninstall.. you need to drill the rivets out of the motor dis-assm
there are 3 nylon bushings that disintegrate... you will need to order
or find nylon bushings... I can give you a.. OD and length later
you will need a paper clip or similar to re-install the brushes on the armature
no vacuum that's from a old vette
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
