LT1 pistons in 91 L98
Old Feb 19, 2011 | 08:12 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
I tore my L98 down recently for a rebuild. Ordered rings for the pistons, only to find out they wouldnt fit, so i tried the other type of rings for the L98, still not a fit. Looked over the pistons real good and noticed they were made by mahle. they are flat tops with 4 relief valves. I researched a bit and found the ZZ4 and LT1 both used this type of piston, but they called for the same rings as the L98 motor. 5/64 5/64 and i dont recall the oil ring size.
does anyone know more info about these mahle pistons? is there a part number on them somewhere i may be able to find?
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
