blocked heat riser passages
Car: '90 IROC-Z 1le
When installing an intake manifold, what's the best way to block the heat riser assuming you have intake gaskets with provisions for heat?
Thanks,
Bobby Z.
Thanks,
Bobby Z.
Car: 88 iroc z28
Engine: Sbc 350
Transmission: 700r4 auto
Axle/Gears: ??????
Re: blocked heat riser passages
I'm pretty sure they make little plates that sit in there...like the ones you get in a stock gasket set with the little holes in them....i would imagine you could get em with or without the holes.
sailtexas186548
Feb 17, 2017 03:07 PM
