Help please
Old Feb 25, 2011 | 10:54 PM
CheckerRs92's Avatar
Help please
Long story short my 92 305 stalled one night took it ti a shop it lost spark replace distributor and coil pack and it ran good so I drive and when I give accelerate highway speeds it back fires and stalls always restarts I drove a week cool but once you step on it gives a pop sound n and stall been to the shop 3 xs plugs wires are good voil pack distrub good timing food no codes adjusted the rich n lean im thinking fuel filter and maybe pump why does it run good at normal speeds but choke out high help plz
Old Feb 26, 2011 | 03:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Help please
Any codes?
I'd find TDC #1 cylinder on compression stroke, then pop distributor cap off and verify rotor pointing to #1 spark plug wire and verify firing order on the cap.
Old Feb 26, 2011 | 04:01 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Help please
sounds like a bad ecm and or prom,but it does still sound ignition related. Is your distributor in correctly? Maybe a tooth off. Like the other member said. Check for codes again even if your engine light is not on.
Old Feb 27, 2011 | 08:47 AM
Vader's Avatar
Re: Help please
Welcome Aboard!
Has anyone checked the valve timing?
