1.6 rockers and valve covers
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, I found some stamped 1.6 rockers, and i am not after reducing friction here either. Just want more lift from the stock cam. So the question is this: These rockers look just like the stock 1.5 rockers and i am wondering if there will be any kind of clearance issue with the stock centerbolt valve covers? Isn't it usually only a problem when the rocker is wider? like a roller rocker?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1.6 rockers and valve covers
Shouldn't have an issue - the issues come in on roller rockers that pivot on a rail rather than the ones that are attached to a stud.
Transmission: 4L80E/4L80E
Make sure the rockers are the self-aligning type. That's what 91's used.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
