Installing OEM Radio
Old Feb 27, 2011 | 06:48 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
My GTA had an aftermarket radio/cd player in it when I bought it. I picked up a Delco Remy stock radio/cassett player awhile back and ready to do the swap out. Before I tear out the aftermarket, are there small brackets used to bolt in the OEM radio to the radio pod ? And if so, does anybody out there have any for sale ? Just like to have everything I need before I switch back to the stock radio. The stock radio I bought came with no mounting hardware.
Old Feb 27, 2011 | 07:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Installing OEM Radio
Should all already be there, unless someone hacked up the metal of the radio pod area to install the aftermarket unit you are removing.
Old Feb 28, 2011 | 03:47 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
GTA radios have a removeable "L" bracket on each side of front of the HU. Sounds like you might be missing those, but they shouldn't be too difficult to fab up. Most of the radio is held in by the rear stem, the front brackets aren't doing that much of the lifting.
The bigger problem is usually the mounting pod. Very cheap plastic that breaks easily.
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
69 Six Pack
Oct 5, 2015 07:51 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
