I Need New Accessory Bracket Bolts!
Old Feb 28, 2011 | 07:56 PM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
I'm rebuiliding my 89 camaro L98. It's been apart for over a year, and has moved between states... I am missing a few parts, a few parts broke during removal, and a few parts were too ratty/rounded to re-use.
I need to attach the accessory brackets, and all I have are 2 studs in the block on the drivers side. I have a couple random bolts and nuts that might fit, but I want to be sure and I especially want it to be correct.
I'd like to just get new bolts to keep things organized and clean. Anyone know where I can get those bolts/studs/nuts in a set? Does GM make a bolt set? I haven't found anything from ARP. I've searched all over Google and Thirdgen, but I haven't found anyone with the same problem.
I'm trying to tie up loose ends before I drop my rebuilt engine back into the car and begin trying to reassemble everything outside the engine and above the thermostat from memory. Thanks for the help guys.
-Cornholio
Old Feb 28, 2011 | 09:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: I Need New Accessory Bracket Bolts!
There just grade 8 bolts, get the right size and snag at any hardware store.
Old Mar 1, 2011 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check link #2 in the first post of the following link for an instruction/parts manual which may be helpful:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
