GM OBD 1 Scanner
Old Mar 2, 2011 | 09:00 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
GM OBD 1 Scanner
I'm wondering if anyone knows of a reasonably priced digital OBD I scanner for the 3rd gen Camaros. I've found a few of the cheap "count the blinking light" type scanners on line but the only digital ones I've seen are the OBD I/II combo scanners that are very expensive.
Old Mar 2, 2011 | 03:00 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: GM OBD 1 Scanner
http://sethirdgen.org/dtc.htm
You could use a paper clip and do it for free.
Old Mar 2, 2011 | 04:53 PM
lonestar7's Avatar
Engine: 5.7L TPI
Yes, I read about that method. Just wondering if there was a cheap digital scanner that would store the codes and run a ECM self test a an a few other simple systems checks similar to the one I have for my old Ford.
Old Mar 2, 2011 | 07:14 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Not sure that any cheap scanner is going to hold the codes.
Most probably be looking at a couple hundred bucks.
I went a simpler route by buying a cheap older laptop from ebay and making a cable which is really easy. Total was around $60. Also bought an ELM obd2 scanner and now I can read any car.
Sadly it does not do abs codes but the laptop stores any codes I want it to.
My tuppence.
Good luck.
Old Nov 4, 2011 | 10:14 PM
Overcome90's Avatar
Car: 91' Camaro RS
I am sorry for bumping an old post but I do not quite understand this process. Can someone explain it as you would to a child lol??? I dont mind, really.
Old Nov 4, 2011 | 10:41 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
But what are you asking, what process?
Old Nov 4, 2011 | 11:30 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
DIY Prom board offers more insight on PC based data logging.
In a nutshell
Buy the ALDU1 from Moates.net or ALDLCable.com sells an all in one cable.
Download software like TunerPro, WinALDL, Datamaster, etc etc. Many totally free packages are available, some with modest licenses fees, and a few with really high fees.
Plug Cable into car and into Laptop
Read data.
Old Nov 4, 2011 | 11:55 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Just use a paperclip or go to Autozone & ask for one of their OBD 1 keys. They gave me one years ago.
junior419
Apr 7, 2025 11:35 AM
92firebirdguy
Sep 10, 2015 10:33 PM
whtltng89
Sep 8, 2015 07:06 PM
Electro_X
Aug 19, 2015 07:59 AM
mizz0313
Aug 12, 2015 06:45 AM
