Fuel Pump In Tank Question
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
I have an 87 Trans Am that has the electric pump in tank and the mechanical pump on the block. If I do away with all the computer stuff can I go without the pump in the tank? Or can you run the pump in the tank with out the computer equipment?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel Pump In Tank Question
Yes, and yes.
What you cannot do is run an external pump that is trying to pull gas through a non-working intank pump - it'll work for awhile, but eventually burn up your external pump.
I'm assuming your thinking of going non-computerized carb - why? Your computer carb is much much better than any other carb you can get, up until about 350 - 400hp, then you'd need a different carb. There really is nothing better than your stock carb setup - keep it if it functions and put any motor under it you like (under that hp).
Engine: 350 Vortec
Yes, and yes.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
