how much to drill out push rod hole?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: how much to drill out push rod hole?
I'm assuming you mean the guide slots in the head and not the actual hole in the pushrod
Coupla ways to go about it...
If your heads have the slots that fit tight to the push rods ( I don't think so, but you might) then you can get the "Louis tool" from Comp http://www.summitracing.com/parts/CCA-4710/ with a 5/16" bit, and continue to use the non-self-aligning rockers, if that's what you've got.
Or, you can just go to town with about a ½" bit, and make sure you drill more toward the rocker stud; and use either guide plates or self-aligning rockers.
Best way depends on what you have now and what your goals are.
Transmission: 4L80E/4L80E
Hotrodboba400
Dec 10, 2019 07:07 PM
Street Lethal
Sep 7, 2015 01:09 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
