LS vs SBC comparison
Old Mar 9, 2011 | 10:04 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
I wrote an essay for a college course comparing these two engines and giving examples of why I feel the LS based engines are superior to the SBC. Now I do not consider myself an expert, and would like to hear others opinions.
Some may find this interesting and some may find this useless, but I figured might as well try to contribute to the board in any way I can.
Document is attached.
File Type: doc
Old Mar 9, 2011 | 10:16 PM
tjtaylor's Avatar
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
Re: LS vs SBC comparison
on page three you used the word suck instead of such i do believe hah but good paper
Old Mar 10, 2011 | 04:33 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
In stock form I agree. In modified form all bets are off!
Old Mar 10, 2011 | 04:53 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
yeah once you look past the "oh stock LS parts are so much better" (they are newer, that's expected) they both have their up's and downs.
also not mentioned very ofter, is the SBC's 5 heads bolts per cylinder VS the 4 for LS. although LSx can have 6 bolts per cylinder, that gets pricy fast.
Old Mar 10, 2011 | 05:27 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
though mod for mod..
on another note, dont LS blocks have 6 bolt mains?
and then there is the fuel economy
Old Mar 10, 2011 | 09:15 PM
brodysZ28's Avatar
Engine: 383
Yea I'm pretty sure all of the LS have 6 bolt mains.
Does extra head bolt per cylinder make a difference? What would happen, bolts stretch or even break?
What are some negative aspects of LS engines besides obviously cost? I know that the aluminum blocks aren't as strong as the same iron ones.
Old Mar 10, 2011 | 09:28 PM
Convoy25's Avatar
the looks of them
and they sound nice, but they dont have that Small block/Big Block sound
Old Mar 15, 2011 | 12:02 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i believe a majority of ls motors have 4 head bolts per cylinder. i know the LSX block and maybe the higher performance stock motors have 6 head bolts per cylinder but certainly not all of them. When you start getting into really high HP build (forced induction especially) the 4 bolts are not enough to keep the heads from lifting
Old Mar 18, 2011 | 07:11 PM
brodysZ28's Avatar
Engine: 383
And when they lift does it just blow the headgasket and lose compression or worse?
Old Mar 18, 2011 | 07:21 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
What are some negative aspects of LS engines besides obviously cost? I know that the aluminum blocks aren't as strong as the same iron ones.[/quote]
The only thing I dont like about an LS engine is there is no one to tune it close to me, When you do mods to it it needs to be retuned and that gets pricey if you can find someone close to do it. The LS is a great motor but an ugly one. my 2 cents.
Mark.
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
