AC delete
Old Mar 12, 2011 | 11:17 AM
my27kgame's Avatar
Car: '86 Iroc-Z, '98 A4 Quattro
Engine: 5.0 TPI
AC delete
I rebuilt the TPI on my car b/c the guy who installed it didnt seal the gaskets and tightened the bolts he could. Is an AC delete as easy as removing the compressor and belt or does that belt drive something else? Its already apart that's why I have the question
Old Mar 12, 2011 | 02:15 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: AC delete
What effect are you going for? If its just to "clean up" the engine bay then you can just unbolt the compressor and run a shorter belt.
If your doing a true A/C delete you'd need to remove everything from the condensor in front of the radiator to the evaporator in the dash.
Having said that, keep in mind your defrost won't work as well because its the A/C system that removes moisture (humidity) from the air thats blown from the vents.
Old Mar 12, 2011 | 02:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: AC delete
Just a small clarification - defrost will still work, just not as well. You'll still get air out of the vents, but it won't be dry air, so it takes a tad longer (like the good old days).
Yes, you can remove A/C compressor - just make sure you still have a belt running the P/S pump and water pump. You can also remove the condensor in front of the radiator, and the evap canister in front of the blower box.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
